This is a great widget. I got the hyperlink to work, but my problem is I can not display the linkfield as an individual field in the grid or the InfoPopup. Ideally, I need that as the first field listed and to also be part of the hyperlink string. The field in the code below is Well Log ID. I tried listing the field twice in the fields list, makes no difference. Any suggestions appreciated. Unfortunately, I don't have a flex compiler, so can only edit the widget.xml.
<layer>
<name>All water wells</name>
<fields>Well Log ID,Aquifer Elevation,Bailing Rate,Depth to Bedrock,Bedrock Elevation,Pump Rate,Screen Length,Static Water Level,Total Well Depth,Owner,Owner Address</fields>
<linkfield>Well Log ID</linkfield>
<linkprefix>https://secure.in.gov/apps/dnr/water/dnr_waterwell?refNo=</linkprefix>
<linksuffix>&_from=SUMMARY&_action=Details</linksuffix>
<iconfield></iconfield>
<iconprefix></iconprefix>
<iconsuffix></iconsuffix>
<zoomscale>9027</zoomscale>
<forcescale>false</forcescale>
</layer>
