Identify Widget- Error #1053 Illegal override of FlexModuleFactory
1270
02-23-2012 07:58 AM
DavidFlack
I have an application built from the uncompiled ArcGIS Viewer for Flex (SDK version 4.5, ESRI API version 2.4).  I had a request to add Robert's Identify Widget to the application.  I was able to find a compiled version and added it to my test app- works great.  Problem is, when I try to move it to the production server Flash throws the following error:
"VerifyError: Error #1053: Illegal override of FlexModuleFactory in mx.core.FlexModuleFactory."
My guess here is that the Identify Widget I grabbed might have been compiled using a different version of the SDK (4.1?).  Am I on the right track?  If so does anyone have an uncompiled version of the widget they could post?  It would be much appreciated.
I would assume upgrading everything to version 2.5 would also take care of the problem, but I would rather not do that to maintain consistency in my environment.
Thanks for your help,
Dave
RobertScheitlin__GISP
Dave,
   Yep, you are on the right track. Here is the uncompiled 2.4 version.
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
Dave,
DavidFlack
Works perfectly after recompiling.  Thanks Robert!
