Hi
I have 32 layers in my flex application.Is there any way to make groups of these layers like ArcGIS Desktop?
I can not do this in ARCGIS DESKTOP, because some layers are cashed and some layers are dynamic.
Regards
Robert, Thank you for your support. I'm really appreciated. This changes seem to work. I was able to compile the source code successfully. Have a wonderful afternoon.
Regards,
Ha Thach
Ha Thach,
I am not sure if you will have this option or not, but if you do can you mark my reply as helpful? To do this you will click the "Actions" menu link on my reply and choose "Mark as Helpful". I am still trying to determine when people will or will not have this ability, so it may not be an option.
Sorry Robert, I don't see that option. All I see is MANAGE and Report Abuse.
Ha Thach,
OK, like I said I was not sure if that was going to be there for you or not.
Great Widget!
But is it easy to change it a little bit?
I would like to change the visibility of all the layers in 1 theme to false when the theme is collapsed and make them visible when the theme is opened.
I have no ability to compile the source code.
I will have a look at adding that functionality in. As well as updating the code to the latest version of the flex viewer.
