How can I get each point of polyline from featurelayer
2382
10-16-2012 05:08 AM
MarcinDruzgala
So here is the question. I have a map service with feature layer that contains polylines. What I need to do programatically is to get all the map points for each polyline in my mapservice - i need x,y,z values. Can I do this?
I tried already few things but nothing works. I can't get geometry property from feature layer because it returns a String value and that doesn't help.
      Creating new polylines with an Array of MapPoints would take too much time(and it's not the way it should be done i think) and since new MapPoint takes only x,y and spatialReference parameters how can I assign a z value? Anyone got idea?
MDruzgala
DasaPaddock
hasZ should be true on your layer if it supports z values. Check for this on the REST page for the layer. e.g.,
http://sampleserver6.arcgisonline.com/arcgis/rest/services/SampleWorldCities/MapServer/1
If your FeatureLayer is not in a Map, it won't have any features loaded into it, but you can call queryFeatures() to get the features and their geometries:
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/layers/FeatureLayer.html#queryFeatu...
BjornSvensson
Assuming you are using version 3.0 or later (as "z/m value support in map and feature services" was added at 3.0 [whats new]).
...for each polyline in my mapservice - i need x,y,z values. Can I do this?
Yes, the map points of the arrays in the polylines should have a "z" property if your feature layer supports "z".
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/geometry/MapPoint.html#z
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/geometry/Polyline.html#hasZ
Not sure how you are doing this, but you should be able to get the x/y/z from each feature in your feature layer.
...since new MapPoint takes only x,y...
This isn't true (if you are using the 3.0 API), see the http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/geometry/MapPoint.html
DasaPaddock
MarcinDruzgala
. Yes I'm using 3.0 Flex Viewer(and ofc 3.0 API).
Well I have my feature service with a layer, let's say named "road" - its a polyline layer that supports 'z' values(and 'm' but thats not the case right now).
Ok so here is what i did:
<fx:Declarations>
 <esri:FeatureLayer id="road_layer" url="http://xxxxxxx/ArcGIS/rest/services/xxxxxxx/FeatureServer/0" returnZ="true"/>
</fx:Declarations>
//And now in Script tag I tried to read this layer details so:
var layerDet:LayerDetails = road_layer.layerDetails;
this is what i get: hasZ = false, hasM = false, geometryType = "esriGeometryPolyline" ( so it's fine - but as i said it's a String only), I can't see any table with mappoints or polyline geometry at all - maybe I'm blind or something..Should I use a outFields with some query to get all the features from FeatureService? And then get arrays of map points of each polyline?
Ok you are right - i did read all the API reference for mappoint and polyline. The "new MapPoint()" takes 3 parameters - x,y and spatial reference(as it's written in API reference) so what I have to do is write something like this:
var mPoint:MapPoint = new MapPoint( 100, 100, new SpatialReference(102100));
mPoint.z = {some_value};
mPoint.m = {some_value};
correct?
Since i've got your attention can you answer my second question which is in here? -> Reload-all-operational-layers-is-it-possible
Thanks guys for answering. I know it's obvious for you but I'm still learning a lot about Flex(and programming as well).
Regards,
MDruzgala
DasaPaddock
