Heat map widget Time enabled="On"
2016
07-12-2013 06:35 AM
azeemirshad
I am using HeatMap widget version 3.3 and it is working great.
I just want to know if there is any way i can enable time by default, because every time i have to go to the settings in heat map widget to turn the Time enabled button to "On".
azeemirshad
Please if somebody can answer the query.....
LloydHeberlie
Hi Azeem,
This functionality is not currently in the widget, but I will try and put into the 3.4 release which should be out very soon.
LloydHeberlie
Hi Azeem,
This has been fixed.
https://github.com/Esri/heatmap-widget-flex/issues/7
https://github.com/Esri/heatmap-widget-flex/commit/bb3f14859249eb4f8b7f0b8abdeff785c32b0a05
https://github.com/Esri/heatmap-widget-flex/releases
