I have two questions regarding formatting the Attribute Table widget: 1. Is there a way to format fields not show all the fields, and select what I need to show? 2. Is there a way to format decimal places?
Cannot see any reference to formatting decimal fields you could try using the format tag in the field properties like you do on a popup, to see if the same code has been used and not documented:
Could you share the solution you figured out? I tried inserting precision="0" and precision="-1" in the field tag of the particular field (type: double) that I am attempting to remove decimals from in the attribute table widget.
