Flex widget load images from JSON works stangely
4257
12-22-2014 06:51 PM
WuYang
Dear all,
I am trying to display the images in flex widget got from JSON. All works except the displaying of the images in the widget.
I have 8 image in design mode of the widget, the source will be assigned at runtime when get the data from JSON. The images will be assigned one by one from image1.
I use the same set of JSON data to test. The strange thing is every time the images displayed in the widget is different, for example, sometimes it displays all the 8 images, sometimes it displays image2, image4, image7, sometimes it displays image1, image2, image5.
The source code I use:
private var value0:String;//id
private var value1:String;// type
private var value2:String;// image url
var request:URLRequest=new URLRequest();
request.url=getUrl;
request.requestHeaders=[new URLRequestHeader("Content-Type", "application/json")];
request.method=URLRequestMethod.GET;
var loader:URLLoader=new URLLoader();
loader.addEventListener(Event.COMPLETE, receive);
loader.load(request);
protected function receive(event:Event):void
var myResults:Array= com.adobe.serialization.json.JSON.decode(event.target.data);
var i:int;
for (i=0;i<myResults.length; i++){
  value0 = myResults.goods_id;
  value1 = myResults.goods_type;
  value2 = myResults.image_url;
  if (!image1.source){
      image1.source = value2;
  }else if (!image2.source){
      image2.source = value2;
  }else if (!image3.source){
      image3.source = value2;
  }else if (!image4.source){
      image4.source = value2;
  }else if (!image5.source){
      image5.source = value2;
  }else if (!image6.source){
      image6.source = value2;
  }else if (!image7.source){
      image7.source = value2;
  }else if (!image8.source){
      image8.source = value2;
Anybody has experience on it? Please advise me, thank you.
Tags (4)
AnthonyGiles
Wu,
not tested but does this work:
for (i=1;i<myResults.length; i++){
   this["image" + i].source = value2;
WuYang
Thank you Anthony for the reply.
I have tried the code above. no error but also no picture displayed.
