ESRI Basemaps and zooming in closer
3690
10-08-2014 12:42 PM
TimHayes
I am using the Flex Viewer 3.6. I am using the ESRI Basemaps. I need to zoom in closer so my users can see more detail. However, the ESRI Basemaps only allow you to zoom down to a certain level. Then you cannot zoom any more. Is there a workaround where I can set up the ESRI Basemaps to zoom in closer? I have read about LODS, will this work?
RobertScheitlin__GISP
Tim,
  Yes adding more LODs will work but once zoom in past the lowest Cache level that esri has then the esri basemaps will not draw and you need to turn on your own data to fill in the gap.
Here is how I have mine configured (Notice the display levels on the esri streets, this tells the map to draw that layer for those display levels only, and then I have a min and max scale set to turn on and off my aerial photography layer:
<map wraparound180="false" initialextent="-9598200 3968200 -9500400 4026200" fullextent="-9598200 3968200 -9500400 4026200" top="40" attributionvisible="false">
        <lods>
            <lod resolution="0.14929107085026672" scale="564.2485881"/>
            <lod resolution="0.29858214164761665" scale="1128.497176"/>
            <lod resolution="0.5971642835598172" scale="2256.994353"/>
            <lod resolution="1.1943285668550503" scale="4513.988705"/>
            <lod resolution="2.388657133974685" scale="9027.977411"/>
            <lod resolution="4.77731426794937" scale="18055.954822"/>
            <lod resolution="9.554628535634155" scale="36111.909643"/>
            <lod resolution="19.10925707126831" scale="72223.819286"/>
            <lod resolution="38.21851414253662" scale="144447.638572"/>
            <lod resolution="76.43702828507324" scale="288895.277144"/>
        </lods>
        <basemaps>
            <layer label="ESRI Streets" type="tiled" visible="true"
                   url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
                   displaylevels="11,12,13,14,15"/>
            <layer label="Aerial Photography" type="tiled" visible="true"
                    url="http://myserverstuff/MapServer"
                    maxscale="564.2485881" minscale="9027.977411"/>
            <layer label="Parcel Data" type="dynamic" imageformat="png32" visible="true" useamf="true"
                    url="http://myserverstuff/MapServer"/>
        </basemaps>
        <operationallayers/>
    </map>
