eSearch (3.6.8) joined table on FClass always returns max # records
7175
28
09-11-2014 12:27 PM
MegPeterson
Hi all -
I'm using the Robert's eSearch widget v. 3.6.8.
I have a feature class with a joined table. Whenever I use the eSearch widget the maximum number of records (n=1000) is returned as if it's selecting everything in the feature class. I know it should only return 3 records based on my search criteria.
The field names in the .xml are set correctly based on the REST service between the two tables:
  • Special_Status_Plants_info.SCI_NAME ( type: esriFieldTypeString , alias: SCI_NAME , length: 64 )
  • Special_Status_Plants.PARK_CODE ( type: esriFieldTypeString , alias: PARK_CODE , length: 8 )
The only difference between this feature class and others that are working correctly in the same service is the join.
Any ideas if this is a bug? I'm having trouble navigating the GeoNet site to look around.... And actually - anyone have a beginners guide to how to even use the GeoNet site!?
Many thanks,
Meg
RobertScheitlin__GISP
Meg,
   Does your layer or your table have a subtype?
MegPeterson
No it doesn't. It's a many-to-one join, if that sheds light on anything.
Thanks for the prompt response.
Meg,
   I have seen this before but I thought that it was associated with a subtype... Can you test your query in the Rest Service Directory page for your layer and see how many results are returned?
MegPeterson
Hi Robert -
I was able to query in REST with a record return = 12. I've attached the screen shot of one of the records so you can see if any Field names trigger thoughts.
Many thanks.
Meg,
   Is the data publicly available for me to test?
MegPeterson
It's not, but I can send you a subset of the data via DropBox. Would that work?
Sure that would work
MegPeterson
Hi Robert - I have the file ready in dropbox. My email is mpeterson@ebparks.org
If you can send me a quick email, I can drop you the link (unless there is another way I'm not aware of).
thanks, Meg
Meg,
  Once I fixed those issues I mentioned in the XML then I was able to search by SCI_NAME for Fritillaria and get 117 results
