error 1009  - Enhance search
2464
5
02-20-2012 02:09 PM
JamesArmstrong
Finally found some time to work on the flex viewer again.  Downloaded latest enhanced search widget and read the pdfs.  Seems pretty straight forward, so first off,need to acknowldge Robert for his good works.
Anyway,  been trying to use the enhanced search widget with my own data and having some issues.  namely Error 1009.
here is search config that I am using to search my parcel data.  I get the data visually as a dynamic layer so all seems good there.
any thoughts?
<configuration>
<layers>
  <layer>
   <definitionexpression></definitionexpression>
   <enableexport>true</enableexport>
   <name>Parcels</name>
   <url>http://rcggisserver2/ArcGIS/rest/services/RichmondParcels10/MapServer/11</url>
   <expressions>
    <expression alias="PIN2"
     textsearchlabel="Search by Parcel ID [Example: 746604927130]:">PIN2 = '[value]'</expression>
                        <!--<expression alias="OwnerName"
     textsearchlabel="Search by Owner Name [Example: Smith,John or Smith%]:">OwnerName LIKE '%[value]%'</expression>-->
   </expressions>
   <graphicalsearchlabel>Use one of the graphical search tools to select parcels</graphicalsearchlabel>
   <spatialsearchlayer>true</spatialsearchlayer>
   <titlefield>PIN2</titlefield>
   <fields all="false">
    <field name="PIN2" alias="PIN2" />
   </fields>
   <links>
    <link includeinresults="false" field="" alias="">
     <linkprefix></linkprefix>
     <linksuffix></linksuffix>
     <iconfield></iconfield>
     <iconprefix></iconprefix>
     <iconsuffix></iconsuffix>
    </link>
   </links>
   <zoomscale usegeometry="true">40000</zoomscale>
  </layer>
by Anonymous User
Not applicable
Original User: Richmondgis
Robert
Yep, that seems to have been the trick.  More times than not, it is something simple...
thanks again
james
RobertScheitlin__GISP
James,
   I don't see an issue in what you posted so you might want to attach your whole SearchWidget.xml
by Anonymous User
Not applicable
here attached is full widget (sent as a .txt file.)  I have deleted some of your orginal code like the zoning district search and other that were commeted out anyway.
Perhaps I deleted something important......
sometimes I get the #1009 error and other times the return is 0.
I did try to use the ip address in the url but that did not help.  Also currently this Server is not yet available to the public.
James
James ,
   Do you have the ObjectId and/or Shape field hidden in the MXD for this layer if so that is the issue.
by Anonymous User
Not applicable
Robert
thanks again
james
James
Glad you got it working. Don't forget to click the Mark as answer check (on my post) and to click the top arrow (promote) as shown below:
