Enhanced Search not honoring zoomScale
2777
14
05-12-2011 01:09 PM
JayGeisen
For some reason, when I click on a returned record in the eSearch widget, it zooms all the way in instead of honoring the scale I have set in the xml file.  Any ideas why this might be (probably my doing I would bet)?
RobertScheitlin__GISP
Jay,
   OK, I think I understand you to be saying that you are trying to take my updated code and adding it to an older version?... If that is the case than you are missing several other pieces of new logic that were added. A large portion of the clickSearchResult function has changed as well as other functions to support the fix I put into place.
JayGeisen
Yes, that is what I'm trying to do.  I also tried using the 2.4 version of your eSearch in my 2.31 SFV.  Under that situation, I am still not getting the desired result.  I realize you don't want to get into supporting old versions, but is there any way to easily code a set scale into the clickSearchResult function until I can get my SFV updated to 2.4?
Jay,
  OK using the 2.4 Version of this widget in Flex Viewer 2.3.1 is not a good test as there is portions of the code in the last couple of releases that is dependent on Flex Viewer 2.4... Hence the 2.4 version of the widget. So my advice at this point is to look at the difference in the clickSearchResult function by opening the new 2.4 version and searching for isNaN(zoomScale). That might get you to all the right spots in the updated code base.
JayGeisen
Thanks, Robert.  I will attempt to do that.
JayGeisen
Robert,
I got it to work in version 2.3.1.  Thanks again!
Jay
