Editing Viewer 2.4's Pop-Up Skin
5905
33
08-11-2011 08:51 AM
ChadKijewski
Hey all,
I was wondering if anyone could impart any insight regarding altering the skin of the built-in pop-up utility.  In particular, I'm trying to figure out how to remove the 'Zoom To' button that automatically appears at the bottom of each generated pop-up.  I'm going through the compiled source code now but unfortunately I can't seem to find a particular MXML that governs the popup's skin, and was hoping someone could point me in the right direction.
Thanks for any help in advance.
TonyAlmeida
MVP Regular Contributor
Does anyone know how to change the color popup with out changing the header?
RobertScheitlin__GISP
Tony,
  Look at adding some css to the default.css in the default package folder
    esri|InfoWindow
            content-background-alpha : 0;
            background-color : yellow;
            background-alpha : 0.8;
            border-style : solid;
TonyAlmeida
rscheitlin.
Thanks for the replay,
I add the following code you pasted to the defaults.css and nothing changed???
DianeWhited
Does anyone know how to change the width of the column for the output results.  I see labelwidth changes the column width for the filed name, but would like to widen the output column also.
Thanks.
chuckfrank
Thanks.
If you go into the PopUpRendererSkin.mxml and scroll down around the middle of the code you will see
label.width = 143;
  Change the 143 to the desired width.  In my file it was on line 174.
DianeWhited
Thanks Chuck that did the trick.  Much appreciated!
RicardoCuitiva
I need to create a query, but the I need some differents fields in my Pop-Up window, because it read the fields from the XML, I need that it read these fields from other label and maybe in the same XML config.
Please help with this.
Thank you very much.
Ricardo
MiguelRueda
Hi Everyone,
I'm trying to make PopupWindow to take alternateColorItems property, but i can't do it, i'm trying to show every item that the popup shows to looks like a datagrid row using  alternateColorItems property adding this to the VGroup element that it's in the PopupRenderer.mxml class. Is something i'm doing wrong, or what is the proper way to do it?
Any help is aprecciated.
Regards,
Miguel.
Miguel,
   You are editing the wrong file. You need to be editing the PopUpRendererSkin.mxml. Then you need to know if the popup is configured using the description or individual fields (these are two different code paths).
MiguelRueda
Miguel,
Hi Robert,
I'm sorry i mistyped, actually I'm editing PopUpRendererSkin.mxml. Well, i have configured the popups to use individual fields is this the problem?
This is a sample of what i'm looking to do with my popup window
[ATTACH=CONFIG]17828[/ATTACH]
Miguel.
