Draw Widget for ArcGIS for Flex 3.6 - Default to show measurements
1325
02-12-2014 03:40 PM
GregSnelling
Has anyone set the Draw Widget to default to "show measurements" when the tool is opened?  Can this be done inside the .xml config for the the Draw Widget?  Please help.
Greg
RobertScheitlin__GISP
Greg,
   Sure just add this to the xml:
<measure>true</measure>
Docs: http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Draw_widget_tags/01m30000000z00...
deleted-user-x9uzN2EPWyEQ
GregSnelling
Thanks again Rob.  Next time I'll check the help ESRI documentation before posting.
Your help is very much appreciated.
Greg
