Display USNG Coords from State Plane (NAD 83) Service
4071
02-26-2015 07:30 AM
DanielJohns
Greetings,
We're starting to incorporate the USNG in our operations. Our Flex GIS website is setup with base map services that are projected in NAD 83 (Florida East). I've seen the USNG / MGRS widgets but my goal is to use our internal map service which has the USNG for just our state and counties. If I change the coordinates inside of ArcMap everything projects properly and the grids look great.
I was wondering if it's possible to just change the Coordinate Widget to pull the coordinates as USNG / MGRS based on our service, currently it's pulling feet.
Thank you,
Daniel
Tags (3)
larryzhang
thanks, you posted this question.
Also interested in an existing Flex widget to display /two-way transfer a local projected coordinates (x, y) from/ to WGS 84 (geodatic Long/Lat)...
If someone can share, would be great...
larryzhang
The Coordinate widget is available here ArcGIS Viewer for Flex
It supported values are 'geo' (Geographic), 'dms' (Degrees, Minutes, Seconds), and 'mercator' (Web Mercator).
