Disable move of the Polygon
876
07-17-2012 07:01 AM
PriyaRam
I have attached a MouuseEvent.click to each of my FeatueLayer and I want to disable the move of the polygon
(oplList.layer as FeatureLayer).addEventListener(MouseEvent.CLICK,polygonSelectHandler);
In the polygonSelectHandler , activate method I just pass the Edit Vertcies alone , but I'm unable to disable the move. I also tried changing in the editor.editTool.activate method.Please direct , how can we handle this situation.
private function polygonSelectHandler(event:MouseEvent):void
    try
     if (event.target is Graphic)
      editGraphic = Graphic(event.target);
      lastActiveEditType = "none";      }
     if (editGraphic.geometry is Polyline || editGraphic.geometry is Polygon)
      if (lastActiveEditType == "none")
       isEditing = true;
       lastActiveEditType = "moveEditVertices";
       myeditTool.activate(EditTool.EDIT_VERTICES, [ editGraphic ]);
      else if (lastActiveEditType == "moveEditVertices")
       isEditing = false;
       editGraphic = null;
       myeditTool.deactivate();
        else
       isEditing = true;
      else
       isEditing = false;
       editGraphic = null;
PriyaRam
Is it possible to disable move of the polygons in the EditWidget.mxml and what would be the right event to trap. should I atatch map click event to the Feature layer or the map or the Graphic.I would appreciate, if someone could give some leads in the right direction.
PriyaRam
When using the FlexAPI and using the edit tool as a standalone(see attached txt file, rename to mxml), the editTool.activate passing only the edit_vertices disables the move, but not with the editor that comes with the editWidget. Also I get a warning message unable to bind Graphics to GraphicsLayer when selecting the polygon, not sure if this a bug that is preventing this behaviour from happening. is there a work around to disable the move of the polygons
