Closing Widget in Flex Viewer 2.4
1080
08-16-2011 05:50 AM
sreeharikottoormadam
How to close a widget completely in flex viewer 2.4?
clicking the "x" in upper right is not closing the widget completely. I need to close a widget and open it newly (need to get initialize and widgetConfigLoaded events)
tried the below code in my widget but doesn't seem to work. Next time when I open the widget, it is not even capturing the events initialize and widgetConfigLoaded.
//open the widget
AppEvent.dispatch(AppEvent.WIDGET_RUN,ViewerContainer.getInstance().getWidgetId("MyWidget"));
//close the widget (closed="widgetClosedHandler(event)")
private function widgetClosedHandler(event:Event):void
   AppEvent.dispatch(AppEvent.WIDGET_CHANGE_STATE,{id:this.widgetId,State:WidgetStates.WIDGET_CLOSED});
any help?
KeithGerhartz1
Did you ever get an answer to this? I am also trying to address. Thank you.
HaroldBostic
One issue maybe that the s needs to be lowercase in
should be
state:WidgetStates.WIDGET_CLOSED
omega_cancer
Why do you want to re-open it any way?
I was having the same issue of re-loading settings, layers and other stuff,I solved it by catching initialize, widgetConfigLoaded and addedToStage events in conjuction with a global bool variable to hold value to see if it is fresh run for the widget or it was closed.
It is working for me in many widgets right now.
