Change the subtitle of flex viewer dynamically from widget
3247
8
09-20-2011 06:20 AM
SaugatJoshi
Hi all,
Is there a way I can change the subtitle of the Flex viewer dynamically? I have a list of tags in a combobox eg: tag 1 , tag 2 and so on in the LayerList widget. When i click on tag 1 it changes the layer visibility and now I want the tag name appear as a subtitle in the Flex viewer. How can I achieve this.
The snippet below does not seem to work. I must me missing something here....
configData.ViewerUI.subtitlle.value
Thank you.
RobertScheitlin__GISP
Saugat,
   This is what you need:
AppEvent.dispatch(AppEvent.SET_TITLES, { title: "Hello", subtitle: "World" });
SaugatJoshi
Saugat,
Robert, Where does the addlistener go for this dispatched event?
Thanks.
Saugat,
   You don't have to add one the viewer already is listening for this event.
SaugatJoshi
Robert thanks,
I am using viewer 2.3.1 and do not see it defined anywhere.
Saugat,
   OK, you didn't tell me Flex Viewer 2.3.1... I will have to look how to do this in 2.3.1
SaugatJoshi
Robert,
For this I think in the layerList widget.
ViewerContainer.dispatchEvent( new AppEvent("subtitleChanged",subtitleP);
Then in init() of Mapmanager.mxml
ViewerContainer.addEventListener("subtitleChanged",changeSub);
,and
private function changeSub(event:AppEvent):void
    configData.ViewerUI.subtitlle.value=event.subtitleP.toString()
Do you think this is a correct way?
Saugat,
   No there is nothing that is listening for a change to the configData.ViewerUI.subtitlle.value you would have to add:
to the headerControllerWidget.mxml and add the changeSub fuction that would change the
bannerSubtitle.text =event.subtitleP.toString();
SaugatJoshi
Thanks Robert,
Solution works fine.
-Regards
