I have a widget with some functionality that can load services via a config.xml that might help.http://www.arcgis.com/home/item.html?id=ca9e4de998714d07a6bdc59ededa0efc
 * Takes URL for a ArcGIS Server Rest directory and
 * will attempt to extract the SiteMap.
 * @param directory
protected function loadServices(servername:String):void
 var service:HTTPService = new HTTPService();
 var sitemap:String = "/ArcGIS/rest/services/?f=sitemap";
 var url:String = "http://" + servername + sitemap;
 service.url = url;
 service.resultFormat = "e4x";
 var token:AsyncToken = service.send();
 token.addResponder(new AsyncResponder(onServiceResults_handler, onFault_handler));
 * Handles the results of accessing the SiteMap.
 * @param event
 * @param token
protected function onServiceResults_handler(event:ResultEvent, token:Object = null):void
 var xml:XML = event.result as XML;
 var xmlColl:XMLListCollection = new XMLListCollection(xml.children());
 var list:Array = [];
 var qn:QName = new QName(sitemapNS, "loc");
 var sxml:XML;
 for each (sxml in xmlColl)
  var url:String = sxml[qn].text();
  var tmp:Array = url.split("/");
  var i:uint = tmp.length;
  if (tmp[i-1] == "MapServer")
   var item:ServiceItem = new ServiceItem();
   item.serverType = tmp[i-1];
   item.name = tmp[i-2];
   item.url = url;
   list.push(item);
   findServiceDetails(item);
 list.sortOn("name");
 dataList = new ArrayList(list);
 vUrls = new Vector.<String>(list.length);
 servicesList.dataProvider = dataList;
 * Parses <code>ServiceItem</code> object url to find layer details
 * in service REST.
 * @param item
protected function findServiceDetails(item:ServiceItem):void
 var jsonurl:String = "?f=json&pretty=false";
 var url:String = item.url + jsonurl;
 var srv:HTTPService = new HTTPService();
 srv.url = url;
 srv.resultFormat = "text";
 var token:AsyncToken = srv.send();
 token.addResponder(new mx.rpc.Responder(onJSONResult_handler, onFault_handler));
 function onJSONResult_handler(event:ResultEvent):void {
  var data:String = event.result.toString();
  // this regex replace can be used to make parsing the JSON faster.
  // It removes spaces, but it will mess up service description.
  //data = data.replace( /\s/g, '' );
  var details:Object = JSON.decode(data);
  item.description = details["serviceDescription"];
  if (!details["singleFusedMapCache"])
   item.type = DYNAMIC;
  else
   item.type = TILED;
This will get you as far as loading the individual URL's for each service in a server, like "sampleserver1.arcgisonline.com", then you can create a layers using the URL and pull out the Layer info via layerInfos. I have a function for another tool that does just that.
 * Will find all the items that make up a given map service layer.
 * @param lyr
protected function findLayerDetails(lyr:Layer):void
 if (layers)
  layers.removeAll();
 layers = new ArrayList();
 var layerInfos:Array;
 layerIDSet = null;
 layerIDSet = {};
 if (lyr is ArcGISDynamicMapServiceLayer)
  layerInfos = ArcGISDynamicMapServiceLayer(lyr).layerInfos;
 else if (lyr is ArcGISTiledMapServiceLayer)
  layerInfos = ArcGISTiledMapServiceLayer(lyr).layerInfos;
 else if (lyr is FeatureLayer) {
  var lyrId:int = FeatureLayer(lyr).layerDetails.id;
  var lyrName:String = FeatureLayer(lyr).layerDetails.name;
  layerIDSet[lyrName] = lyrId;
  layers.addItem(lyrName);
 if (layerInfos)
  var info:LayerInfo;
  for each (info in layerInfos)
   layerIDSet[info.name] = info.id;
   layers.addItem(info.name);
