after v2.5 upgrade: ???Error #2124: Loaded file is an unknown type.???
1662
6
03-22-2012 11:01 AM
AshleyOwens
After upgrading from ArcGIS Viewer 2.1 to 2.5, I get error ???Error #2124: Loaded file is an unknown type.??? for any HTML file I attempt to load (such as help or legend files). Has anyone else experienced this?
Thank you,
Ashley
RobertScheitlin__GISP
Ashley,
   That's what I was afraid of... And you are saying this exact setup worked in 2.1?... You need to look at the link widget:
http://www.arcgis.com/rc/item.html?id=5e4717fe1bb247f89b9092308e569c30
What you are attempting to do will not work...
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote) as shown below:
Ashley,
   What do you mean?... When you load HTML files in what?
AshleyOwens
Sorry...when I'm requesting them inside my Flex Viewer application, such as clicking on a menu item for our legend.
Ashley,
   I just need a little more detail... When you say menu Item you mean what exactly?
AshleyOwens
In our config XML file, we have
<widgetgroup label="Help" icon="assets/images/i_help.png">
    <widget label="Help"   left="100" top="90"
                config="Link"
                url="assets/help/TIGERHelp1.html"/>
    <widget label="Legend"   left="100" top="90"
                icon="assets/images/i_resources.png"
                config="Link"
                url="assets/legend/legend.html"/>
    <widget label="Contact"   left="100" top="90"
                icon="assets/images/icon_contact.png"
                config="Link"
                url="cmt.html"/>
</widgetgroup>
Clicking any of these causes "Error #2124: Loaded file is an unknown type." I can load each of these HTML files if I go to the URL directly, and not through our application.
Ashley,
AshleyOwens
I've successfully implemented your Link widget.  Thanks so much Robert. You rock!!
