Advanced print solution
153614
296
02-19-2011 10:52 AM
TomSchuller
Please find in the codegallery my first version of an advanced print solution:
http://www.arcgis.com/home/item.html?id=6809086326ea4c76bf026a32bb9dd698
The backend is developed in Java as a ServerObjectExtension: PChPrintSOE
The communication to the SOE is realized by the REST.
So, any client can be used Flex, Javascript, ...
I just created a simple FlexWidget.
Some features:
- full print over the rest api (usable by any client)
- export to pdf,jpeg,png,emf and mxd!
- view paper layout extent live on map
- make print on a "template" mapservice by keeping the predefined layout
- multi-mapservices/multi-server support
- add graphics on the map view positioned in map units
- add elements on the layout view positioned in paper units like scalebar, scaletext
The code is under full development:
- support for wms layer
- code clean up and reorganization
Any suggestions, remarques or help is welcome.
Live demo with public Esri mapservices (last print button):
http://gis.pch.etat.lu/flexViewerPrint/
   - use this print widget with your PChPrintSOE-enabled mapservices for high quality
   - draw first some graphics with the DrawWidget prior making your print (in mxd format)
TomSchuller
Eric,
I updated the most recent downloads on the server.
Tom
TomSchuller
David,
could you try to create a new AGS-connection in ArcCatalog:
- start ArcCatalog
- GIS Servers
- add ArcGIS Server
- Use GIS Services
- Internet Server URL
      http://swarcgis001/ArcGIS/services
- Finish
You could also try to acces your REST-page:
http://swarcgis001/ArcGIS/rest/services/
Browse to a mapservice and click on top of the page to "View In: ArcMap"
Tom
DavidCaussin
Tom,
For the first thing, i can't create a "use gis server" connection. only a local  without problem.
For the test with arcmap, the mxd open with the map service but with the path problem 😞
TomSchuller
Seems that you ArcGIS server isn't well configured. You should try to run the PostInstallation again and/or check your firewall and WebServer settings.
Tom
DavidCaussin
I think too that it is a problem from the settings (firewall or other) but i dont exactly what to search
TomSchuller
You should post this to the specific forum:
ArcGIS Server Java or .NET
Tom
EricVenden
Eric,
Tom
Tom,
Has the code changed from the beta I downloaded?
Eric
TomSchuller
There are some minor bug fixes.
Tom
EricVenden
Tom,
I have attached the generated mxd from the print as well as the pdf.  You will notice that in both, the TOC/legend contains the parcel lines feature, but does not include the actual parcel lines.  The particular service that is being left off the print is named: Parcels.  This map service contains numerous layers, some of which I have coded to be left off the legend.  ThereIf you need the URL from the the print let me know.
Thank you for your time.
Eric
TomSchuller
Eric,
yes please provide the url.
Tom
