activate graphical search by point after loaded SearchWidget
1175
9
06-12-2014 02:01 AM
NatashaManzuiga
Hi, how can activate the Graphical Search by point after I load the SearchWidget?
Naty
NatashaManzuiga
I just added the function after basewidget_widgetConfigLoaded:
setMapAction("mappoint", "Draw Point", drawSymbol, searchDrawEnd,null,false);
In this function the last parameters means that I set the ShowDrawTips to false..
I want to change the default tooltip that say Click to Add a point...How can I do?
Naty
RobertScheitlin__GISP
Naty,
   The viewer team has not given us tht ability yet. But I have made the enhancement request to 3.7 already.
NatashaManzuiga
Naty,
Thanks Robert, I used that workaroud and it's ok for me!! 🙂
Robert, what is the right way to customize the InfoWindow of the SearchWidget.mxml?
Naty
NatashaManzuiga
Naty
I added the file PopUpRendererSkin.mxml and I customized my popup 🙂
how can I resize the popup?
Naty
Naty,
   There are lots of threads/posts about changing the size of the popup. Just adjust the width and or add a height attribute to the SparkSkin.
http://forums.arcgis.com/threads/28487-PopUps
NatashaManzuiga
Naty,
Thanks Roberts, but if I want to make the popup resizable like Widgets?
Naty
Naty,
   I have not done a lot of testing on this change and I do not intend to spend any time supporting these changes, but here is the code necessary for a resizable popup.
RhettZufelt
MVP Notable Contributor
Hi Robert,
Nice changes to the skin, really like the option of resizing the infowindow to "fit" the results and is working fine.
However, I have noticed that if you have related records, once you push the "Show Related Records" tab, the resize option no longer works until you reload the flexviewer (even if you Hide Related Records).
I know you do not intent to spend any time supporting these changes, but wondering if you might have an idea as to why this "breaks" it and point me in the right direction?
Thanks again,
R_
Rhett,
  I would assume that it might have something to do with the showRelatedRecords_changeHandler function in the PopUpRendererSkin.mxml where it does hostComponent.width = hostComponent.width * 2;
