A Snapshot Widget for FlexViewer 2.1
3613
10
10-23-2010 05:22 AM
ErwanCaradec
This is a Snapshot widget for FlewViewer 2.1
wich allow you to take a snapshot from an area of the map and save it as JPEG or PNG file (with an optional geolocation world file in a zip archive)
View in the code gallery :
http://www.arcgis.com/home/item.html?id=3803b1ec34b446b684b80a067e4d133c
Erwan
ErwanCaradec
here is a new version for the FlexViewer 2.2
The selection rectangle is now movable and resizable.
Erwan
EricVenden
Erwan,
My image has a dark background.  Have you ever seen this behavior?  I haven't added any background color to my config.xml file.  Attached is a screen shot.
Eric V
Guree, IL
ErwanCaradec
Eric,
i think your layer is transparent and your flexViewer as a white background, is'n it ?
When you save the image, (try as JPG and as PNG please) does the image saved have a black background too ?
Erwan
EricVenden
Erwan,
Yes, the saved image in jpeg shows as black.  The png format looks fine.
My FlexViewer has a white background.  The map services I use as Basemap layers are tiled - PNG8 & JPEG
Eric
ErwanCaradec
Eric,
coul'd you please post the REST end points of the basemap services used ?
Erwan.
EricVenden
Erwan,
I have 5 basemaps, none of which are publicly accessible.  I have all the basemaps tiled.  4 of the 5 are aerials and 1 is a "google-like" streets basemap.  How should I post the endpoints?  I have attached a PDF of one of them.
Eric
EricVenden
Erwan,
Can you give me some guidance on why the background of the jpg image is black?
Eric
CarolineCochrane
Hi, thank you very much for this useful widget. I wondered if tehre was a way to include the Overview map into the image if this is displayed in the map?
Thanks again,
Caroline
ErwanCaradec
@caroline1981 : Thanks for the suggestion, i'll include it in the TODO list.
@ericv : I reproduced your problem, whith a tiled service cached in a mixed format. I try to find a solution.
Edit : The JPEG Encoder in Action Script 3 does not support transparency .... you'll have to export in PNG if you need it.
