Hi there,
I am having a hard time editing multiple records at once with Velocity's spatiotemporal layers. Velocity output layers seem to lose a lot of functionalities you would expect from regular hosted feature layers.
Two strategies I frequently use for editing involves using field calculator in ArcGIS Online, and ArcGIS Pro editing. However, these two options are also not available when it comes to spatiotemporal layers. Please see attached screenshots.
I understand it's possible to perform these operations using the REST Endpoint, but it is cumbersome when you are making changes in a test/development environment, or doing proof of concepts.
@PeterNasuti
