Visibility issue of roads
518
06-30-2021 07:46 AM
EmmaThom
I am using the vector tile style editor and trying to make roads visible from a lower zoom level.
For example, using the Road/Local/1 (Line) the default zoom visibility is set to 12. I have lowered this to 9 in the settings but if you zoom out from 12, the Road/Local/1 (Line) still disappears.
Why is this happening? It says the available range is 5-23.
I am using the Light Gray Canvas base.
EmmaThom
Bump.
I have also emailed esri direct a week ago and not had a reply 😕
nicofierrov
Same issue
