Utility Network from FGDB to SDE
1428
03-15-2021 01:21 AM
SergioOrdás
New Contributor II
I am trying to find out if it is possible to copy a Utility Network .gdb with data from my laptot to a .sde stored in a server without a problem or, do I need to follow any spectial proccess? (Keeping in mind the the UN .gdb has been slightly modified with new fields and domains). Thanks.
MelissaJarman
The utility network package tools are the best method to migrate a UN currently.
The team has spent some time to get core data transfer tools like copy/paste and XML Workspace documents to allow the transfer of a utility network at the feature dataset level - these will be available in a future release.
https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/utility-network-dataset-administr...
MelissaJarman
Song_Li
New Contributor III
@MelissaJarman sorry to post an irrelevant question here as I have trouble to create a New Post here. It requires 3 labels, There is no label list for me to chose from and whatever words I put or no put there. It doesn't allow me to send. Can you please help?
MelissaJarman
I DMed  you to see if I can help.
