After reading through various documentation and searching the Community board, I have yet to find a summary that thoroughly explains - with full examples - what's possible for bulk tracing a UN.
I'm on Enterprise 11.3, UN version 7, Pro 3.3.3.
My goal is to use either Python API or ArcPy for the following:
While looping through each of our water UN's ~77,000 line features...
Benefits of this approach:
What works, what doesn't, where I lack knowledge:
Before going into specifics, my frustration is centered around the fact that it's hard to find a method that allows me to dynamically define my starting point (as a mid-point of each water main) for each iteration and then retrieve results in memory...preferably while running against a no dirty area version that is free from interruptions.
In ArcPy I cannot seem to reference a version other than SDE.Default. I've tried appending syntax like this "?gdbversion=[email protected]" (both with and without forward slash before the "?") to the URL for the UN layer, but it doesn't seem to take.
TraceLocations = [{
"traceLocationType": "startingPoint",
"globalId": GlobalID, ## example: "{288D22C3-301A-44D1-81BA-E66F094413D9}"
traceConfiguration = {
"includeContainers": True,
"includeContent": False,
"includeStructures": False,
"includeBarriers": True,
...etc.
resultTypes=[{"type":"elements","includeGeometry":False,"includePropagatedValues":False,"networkAttributeNames":[],"diagramTemplateName":"",
"resultTypeFields":[]}]
trace_results = UtilNetMgr.trace(locations=TraceLocations, trace_type="isolation", configuration=traceConfiguration, result_types=resultTypes)
It's supposed to produce a dictionary with {"traceResults": {"elements": list,}"success": bool}
Here's how it looks when my trace completes. With all the variations I've tried, I never see "traceResults" or "elements" returned.
Here's my strategy to be most efficient: Instead of having to trace all 77,000 features, what I'll actually trace will be much less - perhaps as little as 1/10 of this total. For each line traced, I'm capturing all the lines being isolated from that run. Therefore, I already know that full group of lines is covered by a certain combination of barriers (valves). So I can then insert all those rows into my SQL table before moving on to a new isolation area, if that makes sense. I really just need to trace one line segment for each isolation area/group. It could entail 2 lines total or it could entail 18 lines, but it cuts down on a lot of processing.
Solved! Go to Solution.
@Andy_Morgan You can mitigate the risks of pressure zone boundaries breaking if you have editors work in a version, instead of defaulting directly, and ensure they validate all their dirty areas, fix all their edits, and trace or update their subnetworks before posting their versions. This will flag any inconsistent subnetworks before they are posted to default and become everyone's problem.
Right, definitely an important workflow for editors. While that's applicable for typical edits to lines and valves, sometimes a pressure plane expansion could mean a slow motion updating of features as the construction project and engineering discussions go on for weeks or months. In such rare cases where a broken boundary in GIS is going to be intentional (and of course temporary), I suppose we could create a no-edit/static version on the side before breaking the boundaries -- a snapshot while the pressure planes are still sealed -- and use it for re-tracing if an updated bulk trace was needed.
Hopefully there wouldn't be a need to run an isolation trace for that small expansion/modification area under construction, but otherwise for everywhere else at least this once again shows the value of having a pre-traced system that you don't have to worry about the Default version having issues at any given moment.
@RobertKrisher and @MikeMillerGIS:
One last question as it relates to my bulk tracing solution.
I made some good progress but now hit a wall. For roughly 70,000 water main features, it may take around 24 - 36 hours to trace everything and store ObjectIDs of all the isolated lines. However, I also need isolating valves. I cannot find any way to perform a single trace and extract the valves that are actually isolating + the full set of water mains being isolated.
Here's the reason I want both sets. Besides knowing which valves to turn off in case of an emergency, having all isolated lines will allow me to essentially trace one more level out, i.e. a "double isolation trace". This is nice to offer the field crews for critical situations like a busted 24" main. Having the second layer of isolating valves will potentially save the crews time if they cannot shut of water based on the immediate (1st level) of valves to close. So rather than run a bunch of isolation traces from all the results of the first initial trace, I could use the database row to quickly and easily return isolating valves for those secondary lines.
Here's a visual that may help to explain. My starting trace point is the green point in the middle. The valve on the south end is the only isolating valve. The other two circled in red are what I wish to exclude...yet include all those isolated line elements that are selected in the map.
Is it possible to capture this combination in one run, or am I forced to trace the entire system twice if I want to be able to select double isolation valves directly from my database table of pre-traced lines?
The two valves circled above should not be included in my results.
Update after posting
It looks like this question has already been answered:
Is there any way to take advantage of a Connected trace or some other type of faster trace than a second Isolation? That's the main concern, avoiding two isolation traces for the same feature.
Two isolation traces are the only way that I know how to achieve this.
Option 1- It should be faster to do the isolation trace to get the valves, then run a connected trace with the valves as barriers. The connected trace ignore terminal connections and subnetwork controllers, so there is the possibility for it to produce different results.
The reason why it is faster is because a subnetwork trace must analyze the entire subnetwork to determine flow. If you run a connected trace it will only consider the portion of the network bounded by barriers.
Option 2 - If you're willing to parse the JSON for the export, or manually inspect the results, you could run 1 trace then parse the results to find features that match your condition barriers (i.e. closed valves). This is something that the Batch Tracing CoreHost application that I linked to earlier does. Also, because it uses the Tracing API directly it bypasses the GP overhead and should be able to perform that analysis in a fraction of the time. For reference, doing this analysis for Naperville using raw GP takes about 8 hours, using the Pro SDK it takes a few minutes.
Yes, I have already tried...and ditched...Option1, hoping the Connected trace approach might work for round 2 (to get double isolation valves). The problem there is that if the round 1 trace gets all isolated features (lines and valves being isolated) then I don't have the isolating valve(s) defined yet. It's the inverse for getting only isolating valves in round 1 trace: I won't have all the isolated lines, which would be best for cost of outage analysis later on, i.e. how many and which type of customers would be impacted.
So basically, without having isolating valves in round 1 I cannot go further. A connected trace would go inside and outside the isolating group, selecting more valves than I want.
It will take 2 - 3 traces to accomplish what I want: isolated valves/lines, isolating valves, 2nd outer layer of isolating valves. With my SQL Server table capturing valve OIDs for both isolated and isolating, it looks like only 2 rounds of tracing could be enough, with the rest of the output dependent on selecting rows from the SQL table in a particular way. No matter what, though, your Option 2 may be worth starting over with the Pro .NET SDK. At least I have most of the general logic worked out. The Python / GP time for execution is my worst headache right now.
Thanks. I hope to report back with a final solution eventually.
In option 1 you get the Isolating valves, which is the slower isolation trace. Once you've done this, you use the faster connected trace to get all the isolated features. You're still doing two traces, but one isolation trace and one connected trace will always be faster than two isolation traces. The larger the subnetwork that contains the area being isolated, the faster it will be.
Option 2 allows you to do it all with a single trace (choosing include isolated features gives you the isolated features and the isolating valves) but requires the tedious effort of digging through the complete trace result JSON to manually identify the isolating valves. You'll also need to make sure you filter out any false positives when doing this (valves 3972 and 3973 in your example above). Filtering out false positives is a bit tricky, but you'll want to exclude any valves that are barriers (i.e. closed) but still contain results on either side. These are uncommon, but possible. Option 2 can be done with either Pro SDK or Python.
When talking about this with people (where I don't have the luxury of using bolded text) I usually refer to the results as the contents and barriers for the trace instead isolated/isolating.
The terms "contents" vs "barriers" are easier to write. Got it.
As for Option 2, I have the Core Host tracing solution downloaded and have been trying to plug in my own UN connection properties. I can somewhat follow along with what the C#.NET code is doing. I borrowed the example json files to create my own config file (see below). Originally, the error was about geodatabase not being found, but now it's failing on "dataset was not found". I've tried all variations imaginable.
I realize you were pointing me to the Partition_Water_Isolation" json example, but I think for my workflow and the ultimate goal it'll requires me to use "type": "Trace" like the Trace_Electric_Customers.json example.
I don't meant to go too far with troubleshooting here, so unless you have a quick suggestion I'm wondering if there is any example from ESRI that shows how to connect to a UN feature service using .NET Pro SDK. All of the examples I've seen so far use File Geodatabases. Surely, I don't use a .sde file path, since there is mention of portal URL and user/password. The documentation for OpenDataset doesn't help me.
Once I can properly connect, I should be able to figure out the rest in the trace looping and working with the json response to inspect elements.
My current Water_Trace.json file (with sensitive domains/paths and user/pwd values removed)
"analysisName": "Isolation Trace",
"type": "Trace",
"networkSourceName": "UtilNet",
"assetGroupCode": 1,
"domainNetworkName": "Water",
"tierName": "Water Pressure",
"definitionQuery": "",
"namedTraceConfigurtion": "Isolate Lines and Valves",
"inputWorkspace": "https://myserver.domain/arcgis/rest/services/.../Water_UN/FeatureServer",
"sourceUtilityNetwork": "UtilNet",
"outputFile": "C:\\UtilityNewtorkTracing\\ArlWaterTraceResults.csv",
"outputWorkspace": "C:\\UtilityNewtorkTracing\\BatchTracing.gdb",
"outputPoints": "Pressure_Points",
"outputPolylines": "Pressure_Lines",
"outputPolygons": "Pressure_Polygons",
"outputTable": "Pressure_Analysis",
"portalUrl": "https://portalserver.domain/agsportal",
"portalUser": "Domain\\username",
"portalPassword": "password"
Full error message:
12/30/2025 7:50:58 AM: Reading configuration file: D:\OtherProjects\BatchTracingCoreHost\JSON Configurations\Trace_Water.json
12/30/2025 7:50:58 AM: Isolation Trace - Performing analysis
ArcGIS.Core.Data.Exceptions.GeodatabaseDatasetException: The dataset was not found.
---> System.Runtime.InteropServices.COMException (0x80040301): 0x80040301
at ArcGIS.Core.Internal.IGeodatabaseIOP.Geodatabase_GetUtilityNetwork(IntPtr workspaceHandle, String name)
at ArcGIS.Core.Data.GeodatabaseCore.OpenDatasetCore[T](String name)
--- End of inner exception stack trace ---
at ArcGIS.Core.Data.GeodatabaseCore.OpenDataset[T](String name)
at ArcGIS.Core.Data.Geodatabase.OpenDataset[T](String name)
at BatchTracingCoreHost.Classes.BatchTrace.BatchTraceUsingPaths(String inputWorkspacePath, String utilityNetworkClassName, String networkSourceName, Int32 assetGroupCode, String definitionQuery, String sourceFieldName, String outputWorkspacePath, String polygonClassName, String polylineClassName, String pointClassName, String outputTableName, Int32 functionFieldCount, String analysisName, String namedConfigurationName, String terminalName) in D:\OtherProjects\BatchTracingCoreHost\Classes\BatchTrace.cs:line 78
12/30/2025 7:52:17 AM: Isolation Trace - Analysis complete
12/30/2025 7:52:17 AM: All analysis complete
Because it is a service, try using the layer ID or layer name of the utility network as it appears in the rest endpoint for the service.
The Pro SDK can read branch versioned data through an SDE connection, but we don't allow you to trace or edit data. So, for enterprise this process requires a service.
The .NET Batch Tracing Core Host method appears to be no faster than the Python / GP execution. I'm pointing to my production Enterprise feature service for UN and starting points (mid-points of water mains), rather than the Naperville (FGDB). You can see in my screenshot below it's returning elements just fine. No different than how it would look in Python, except Python is a little easier to watch/debug and I've already invested time into the custom actions around the tracing.
Using the same trace configuration (pointing to water pressure tier) it takes ~7 seconds (sometimes barely a second) per trace. Unless you suspect something isn't configured correctly in my .NET solution, I have to assume Python is still just as good as anything. Running the trace directly from REST endpoint is the same time as well.
As for manually inspecting results, I don't think I'm able to parse the results to handle it all in one trace. My condition barriers are defined by a single field in our valves feature class ("Is_PP_Divider" = Yes), not relying on a closed vs open status, and our filter barriers are Category IS_EQUAL_TO SPECIFIC_VALUE Isolating. So there is no way to further dissect the results when this is all I have available. No properties that help me pick out the barrier (isolating) vs contents (isolated).
I think I'll abandon the .NET method and return to my Python solution...which still seems to require multiple traces.
