Question about "Ignore Barriers At Starting Points" behaviour
196
2 weeks ago
MarcoMattioli
Hi everyone,
I have a question regarding the behaviour of the "Ignore Barriers At Starting Points" option during an Isolation Trace.
This is my situation:
So, if I need to isolate this area, I have to close the valve on the right.
If I place the starting point on the left of at least a service line, the results of the trace are as expected:
But if I place it on the right of the service lines, the valve is ignored:
The horizontal line is a single feature from the left tip to the valve, so I can't explain how having a junction between the starting point and the isolating barrier changes the results.
Is it a bug? Is it by design? Is there a workaround?
Marco
MikeMillerGIS
Esri Frequent Contributor
Marco,
   I can repo it on my dataset too.  Definitely seems like a bug.  I would log it.
MikeMillerGIS
Marco,
MarcoMattioli
Hi Mike,
thanks for the feedback. The technical support logged it as a bug. Let's see where it goes.
