How do I find a list of networksourceid?
3973
6
09-07-2021 09:19 AM
LoganSuhr_PSE
Hi Community,
I'm trying to add associations with a REST call and got stuck when trying to identify the 'networksourceid' in the TO/FROM attributes of body.  I'm hoping there is either a table of ids I can reference or that this is identified somewhere else.
When I reviewed previous association adds and deletes, the networksourceid I saw in the calls didn't line up with expectations.  Meaning, I expected the ids to be the same as the layer index in the feature service.  They are not.
Help and guidance are much appreciated!
HusseinNasser2
You can call `queryDataElement` rest call on the feature service and provide the utility network layer id.
https://server.esri.com/server/rest/services/service_name/FeatureServer/queryDataElements
[13] is the utility network layer id
You can find the utility network layer id  querying the feature service definition and looking up utilityNetworkdatasetId "controllerDatasetLayers": {
"utilityNetworkLayerId": 13
HusseinNasser2
LoganSuhr_PSE
@HusseinNasser2,
Thank you!  I got what I needed from your first suggestion.  I'm fairly new to working with the REST API and didn't quite understand you second comment.  Please expand if you like, but I've marked your solution as solved all the same.
HusseinNasser2
The utilitynetwork layer id will be different for each feature service. You can find the utility network layer id dynamically for any feature service (if it exists) by querying the feature service definition.
LoganSuhr_PSE
Ah, thank you.  That helped.  I did not realize it could change from service to service.
krantiYadav75
@HusseinNasser2  When I checked the JSON generated from queryDataElements, it doesn’t include the sourceId attribute. Is there something wrong with my Utility Network service?
HusseinNasser2
Make sure to pass in the correct layerid to queryDataElements that belongs to the Utility network layer, if you don't know it you can pass in empty string and that will pull all definitions of all layers which includes the utility network layer.
sourceId should be there, if its not, the UN likely wasn't published. Go to to the feature service root json definition and look for utilityNetworkLayerId to see if its published.
