Could anybody tell me if there is a functionality matrix on what kind of use of the utility network requires to have an Utility Network user type extension (GIS Professional Standard/Advanced or the add-on on other user types)?
In example, I would like to know if it is possible to view and trace the utility network without the user type extension in a webapp in Portal or in an Esri app ?
Vish Apte found it for you
To "view" feature classes that participate in UN you do not need UN user type. To run UN traces in web environment, you do need UN user type extension.
I will see if I can dig-out the functionality matrix.
Cheers,
Vish
Thank you for your answer Vish, this already helps me! It would be great if you could dig-out the functionality matrix.
Kind regards,
Thom
