Field Editing of Data in Asset Package
227
10-09-2025 02:19 PM
Joshua_Moreno
We're manually inputting/digitizing data from CAD/Circuit maps into an asset package and aren't very confident with the location of some of our data along with having additional fields like manufacturer and serial number not populated. Before deploying a UN or anything to Enterprise, we'd like to allow our electrical team to be able to verify, provide notes, or correct anything wrong with the data whether it be attributes or geometry.
What would be the best practice in doing this? Our goal is to ensure our data is as accurate as we can get for our field operators to utilize/reference.\
Thank you
MikeMillerGIS
Esri Frequent Contributor
I would run Asset Package To Geodatabase(File or Mobile gdb) and then the Error Analysis Tools(https://pro.arcgis.com/en/pro-app/latest/tool-reference/utility-networks/analyze-network-data.htm)
MikeMillerGIS
gis_KIWI4
@Joshua_Moreno - If it’s attributes like serial number and model number then it may not create dirty areas.
If these attributes are not network attributes then they can just be added later. They will not get in the way of staging the UN from the asset package.
