Failing to Stage Utility Networks on Enterprise geodatabase.
303
11-15-2024 06:01 AM
Yogesh_Chavan
When trying to execute Stage Utility Network Geoprocessing tool in ArcGIS Pro, we are hitting Error:999999 and ImportXML failing.
In some testing we tried importing the Service Territory feature class from the asset package to this SDE, but it fails as well. Importing-Exporting any other layers(non-asset package) works without any issues.
What are we missing? We tried the same on a FGDB, and the UNM was created without any issues!!
Pro version = 3.3
SDE Version =
SQL Server 2022.
MikeMillerGIS
Esri Frequent Contributor
My guess is it is trying to create a 64bit object id, which was not supported in the 3.1 gdb.  Have you tried to run upgrade geodatabase?
MikeMillerGIS
Yogesh_Chavan
Hi @MikeMillerGIS , thank you so much for looking into this.
I tried upgrading the SDE to 3.3 and the issue shows some progress.
Now, the error is quite more precise, do we need any specific user requirement for creating a UNM?
To tackle this we created a new user named UNM with non dbo role and had create, update, delete permissions. This time it gave the same import failed permission error.
Is there anything specific this user is missing?
MikeMillerGIS
I am not sure, The user definitely cannot be a dbo, so check the permissions of the new user.
Yogesh_Chavan
We found some missing permissions on the new user, and updating them worked well and now we are able to proceed.
Thank you @MikeMillerGIS
