Contigent Domains REST SDK access
1703
10-21-2021 03:16 PM
JamesWright9
How might someone via the REST SDK get access to the restrictions defined within a Contingent domain? I am not seeing anywhere in the feature service REST sdk where this information is published.
JamesWright9
Never mind, the contingent domains are not under the QueryDataElements but a new endpoint queryContingentValues
MikeMillerGIS
Esri Frequent Contributor
You have to make a call to QueryDataElement.  This will return the CAV information.
JamesWright9
Hey Mike,
Awesome thank you!
JamesWright9
Well that doesn't seem to contain the information. In our example we setup a bunch of field groups for the contingent domains and doing the QueryDataElements does bring them up, but none of the values are listed.
Here is all the information we get about the field group:
"fieldGroups": [
      "name": "Low Side Voltage",
      "fieldNames": {
       "names": [
        "ASSETTYPE",
        "low_side_voltage"
      "isEditingRestrictive": true
 There should be a list of the 8 values we restricted that group to. Are they listed somewhere else?
JamesWright9
