ArcGIS Pro 2.5: “add tier” tool fails and end up with 999999 error,
1540
14
05-14-2020 11:28 AM
JamalNUMAN
Legendary Contributor
ArcGIS Pro 2.5: “add tier” utility network tool fails and end up with 999999 error,
I couldn’t figure out why “add tier” utility network tool fails and end up with 999999 error.
Jamal Numan
JamalNUMAN
The issue at the moment is that when perfuming the “set subnetwork definition”, I got nothing to add in the “subnetwork controllers”!
What could be the issue here?
Jamal Numan
PaulLeBlanc1
After assigning the terminal configuration to D1/1, you also need to assign the "Subnetwork Controller" Category.
JamalNUMAN
But how to assign "Subnetwork Controller" Category? Which tool do I need appy?
Jamal Numan
JamalNUMAN
I'm revolving in the same circle of situation. Till now, I failed just to set a water device as reservoir (water source) to get the sample network (pipes) traced!
Jamal Numan
