Hello, I struggle with understanding Utility Network. It might be possible that it is easier to teach a dog to ride a bicycle.
I am going through the Tasks provided in Water Distribution Utility Network Foundation, with Water Distribution Editor map. I would like to Locate Leak Location, but I don't get past Adding Trace Locations. The option to Apply added starting points is disabled. I haven't changed anything in the Project File. Network topology is enabled and validated, there are no Dirty areas. I am working on ArcGIS pro 2.9.
It would be highly appreciated if anyone would help me with this confusion.
Cheers!
Hello Anete,
I have seen this before where the trace features path is broken:
Can you check for a valid path and if it is broken set the source to the default geodatabase here:
I hope that helps,
Joel
Hello Anete,
I hope that helps,
Joel
Ran into this exact issue today with the Water Distribution Utility Network Foundation template and going through the Leak Location Task. Remapping the broken paths fixed the issue.
Wanted to follow-up on this thread as I am now testing the Sewer Utility Network and am encountering the same error as before (ERROR 001785: No valid starting locations found.) Thinking it might be the broken path issue, I checked that but to no avail. Paths look good.
Any idea what else could be throwing this error?
