Version 2.5 of Arcgis Pro and the Utility Network Package Tools now allow the deployment of the Utility Network Foundation in a file geodatabase, in addition to the deployment to an enterprise geodatabase. This is a very welcome functionality but it would be more useful if the Electric Network Editor could work with the Utility Network deployed in to the file geodatabase as well. The Electric Network Editor safe a lot of time and already comes with all the symbology for the asset types.
We are moving all the Utility Network solutions from two downloads, the Editor and Foundation to a single solution item, Data Management for Enterprise. This update includes a file geodatabase with the UN created and the editor map is pointed to it by default. Tools are provided to easily move the editor map to another GDB, including an Enterprise GDB. Electric will be updated to this format with 10.9 and be available around May/June 2021.
