ArcGIS Pro 2.5: Utility network appears not to have tools to display flow arrows and set flow direction,
5711
25
06-14-2020 12:05 PM
JamalNUMAN
Legendary Contributor
It would be great if the “display flow arrows” and “set flow direction” get available
ArcGIS Pro 2.5: How to display flow arrows and set flow direction in the utility network,
25 Comments
JamalNUMAN
How about 3.0?
BraydenSAuten
This is a very valuable function that our guys in the field use daily, going from the geometric network to utility network almost seems like going backwards in this instance. Is there any update on the status of adding flow direction?
JamesRains
We are currently making the move to the Utility Network with our Electric, Water, & Wastewater systems. Flow Direction Arrows are a huge part of how we do business currently in ArcMap with the Geometric Network. This definitely needs to be an available option in the UN moving forward.
@DavidCrawford @MelissaJarman @KoryKramer has there been any movement towards adding this functionality to the UN in Pro?
AyanPalit
JamesRains
@AyanPalit I have seen that flow direction is available on a Trace Network. However, we have a Utility Network and flow direction is not available.
To my knowledge, you can not have both networks on the same database. The functionality and detail of the UN is why we chose to go that route. Having flow direction is still very necessary, especially in our Electric System, and needs to be a part of the UN.
(https://storymaps.arcgis.com/stories/963ef30d778a4c549405bcbc1d3bad51)
