Hi, Geonet People!
I have an excel file containing two depth to water table and elevation of the wells.
Note that I'm missing several depth values (blank value).
When I created groundwater 3D map on ArcScene and attempted to show gps of the wells,
I set my shapefile to have 1)extrusion that has an expression as -[aquifer_layer_2].
Then, set ESRI default marker for 2)symbology colored green.
After I applied changes in the shapefile, my ArcScene layer is shown as below.
Is there a way to eliminate the green layer?
What happens if you leave out the missing values?
I tried with <Null> data and putting "0" on blank data values, but still getting the same results.
