Uploading image as a layer
1489
07-28-2022 07:47 AM
JosephBrownsberger
I am trying to upload an image to my ArcGIS Urban plan so that I can overlay it on the map and consequently design zones and parcels around it. I understand how I can add a layer to my map after it is in "My Content" (going to "Manage" and then to "3D Base Layers," clicking the pencil and selecting the layer) but I am at my wit's end trying to figure out how to upload the image into "My Content" as a layer/map in the first place. Does anyone have any advice here?
BethAnnWinebarger
Hi Joseph,
Not sure if its the best, but here is my workflow:
  • Georeference the image in Pro (or ArcMap) -- make sure to use Web Mercator projection
  • Share the image as a Web Layer
  • Select Layer Type as a Tile, place in an ArcGIS Online folder, share with groups as needed
  • Under Configuration - I make sure the scale I need is in within range on the slide bar
  • When you publish it, it will use a fair amount of storage credits for ArcGIS Online, depending on number of tiles it needs to use for the scale range chosen
  • Open it in a new Scene Viewer and save it (I like to add other layers here like streets, surrounding businesses, etc)
  • Then add it to my scenarios under 'Scenario Design Context'
Hope this helps or someone with more experience posts an easier workflow!
Beth Ann
BethAnnWinebarger
Hi Joseph,
Beth Ann
JosephBrownsberger
That's very helpful, thank you!
Till_Schmid
Hi @JosephBrownsberger
I'd like to get back to your question. Since the ArcGIS Urban March 2025 release it is possible to upload an image directly in Urban. See Work with images in our ArcGIS Urban documentation to learn more.
I hope this simplifies your workflow!
