Fail to Sync CityEngine with ArcGIS Urban
755
02-20-2021 06:21 AM
hsinclai
This post is simply a summary repost of a discussion ongoing in "CityEngine Questions" but also deserves to be on the Urban thread.
Issue:
I created a simple street grid in CtyEngine, and I converted my parcels  to static shapes.  I copied the shapes into my Parcels layer with the right scenario turned on. I tried to synchronize these changes with my ArcGIS Urban, but I received this error: "Failed to upload changes for 1 shapes. Run the "Cleanup Shapes" tool on these shapes with "Remove Coplanar Edges" checked and try to synchronize again. Check the log for details."
I did run the cleanup shapes, but still can not sync with ArcGIS Urban. Any suggestion what can I do differently, or why I'm getting this message?
Log Message:
eclipse.buildId=unknown
java.version=1.8.0_151
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64 -data @noDefault
Info
Thu Feb 18 16:45:36 EST 2021
Failed to upload changes for shapes 00000000-0000-0000-0000-000000000000. Run the "Cleanup Shapes" tool on these shapes with "Remove Coplanar Edges" checked and try to synchronize again. - [ModalContext]
****Sometimes it gives error code for "Shape 1040" which is the shapes that were converted from network blocks when using search***
Issue Repetition Video:
https://youtu.be/sYipP67-Oqs
CityEngine Thread:
https://community.esri.com/t5/arcgis-cityengine-questions/fail-to-sync-cityengine-with-arcgis-urban/...
Please let me know if I can provide any other diagnostics.
Best,
Hunter
hsinclai
****WORKAROUND**** I had CityEngine 2020 installed on another computer and repeated my workflow there. It worked! If you have access to CE 2020 try rolling back until the issue is properly resolved. ****WORKAROUND****
