ArcGIS Urban - Improved Drawing Tools
153
10-27-2021 01:50 AM
BrunoSeiler
New Contributor II
The drawing tool in Urban allows to draw right angles, which is a good thing. But there is no feedback on the length of an edge. If you want us to use Urban also to sketch building footprints, we need to have the option to type in the length of the edge  (similar to the CityEngine drawing tool). Otherwise we will need to sketch building footprints in another Software (CAD, CityEngine etc.) and then import into Urban. But this approach is more cumbersome and will not allow to change designs quickly during workshops as it needs much more time.
4 Comments
Till_Schmid
Thanks @BrunoSeiler for this idea.
I can think of several possibilities to support your request:
  1. Show the dimensions while sketching (e.g. with labels).
  2. Support snapping to certain dimensions (e.g. to full meters).
  3. Ability to input exact length dimensions.
Which option would support your workflow the best? Do you need to input exact dimensions or would showing a label work as well? Maybe you have other ideas?
Till
BrunoSeiler
Thanks for your reply!
Showing the dimensions with a label would already be a big improvement and the option of snapping to either full meters or full decimeters an additional plus. Ideally the user would have the option to change the snapping dimension (the options 'no snapping', 'meters', 'decimeters' would work for us), if that's not possible I would opt for decimeters as default.
In theory ;) these two features would pretty much cover our needs and the third option (input exact length dimensions) would not be needed anymore.
Thanks again,
Bruno
Till_Schmid
Thank you @BrunoSeiler for the additional information. We will take this into consideration.
DKossowsky
In addition to these ideas, I would propose:
1) Ability to see measurement while drawing, or save measurements to use later as a reference guide while drawing.
2) Ability to edit parcels by vertex after being created. Currently vertex points can only be adjusted when a parcel is being drawn.
David
