Intersecting a wildfire polygon layer with Areas of Conservation Emphasis
1785
12-26-2023 05:59 PM
AprilWheeler
I am trying to intersect two layers. I am trying to intersect California Fire Perimeters 1879-2021 https://www.arcgis.com/home/item.html?id=6fd0d8d6f47d414da7bcb1dcd0539999 with Areas of Conservation Emphasis (ACE) https://wildlife.ca.gov/Data/Analysis/Ace#523731770-species-biodiversity to determine based on wildfires for the past 10 years, which of those wildfires intersect with the most vulnerable (score 2 or lower) areas of conservation interest. For Species Biodiversity, I am able to select the data that contains a 2 or lower, but I cannot figure out how to intersect Species Biodiversity with the wildfires to show an overlap. I tried the intersect tool and it produced a layer, but it was just a blank map that showed nothing. Please help.
RonaldHaug
MVP
Hi AprilWheeler,
Intersect is good.
You have to make a selection by attribute on the wildfires during the last decade for the fires
and
You have to make a ACE selection by attribute of 2 or less.
You can also use the Calfire data file at https://gis.data.ca.gov/datasets/CALFIRE-Forestry::california-fire-perimeters-all-1/about . I think its a vector file.
There's also a Calfire Perimeter 1950+ file located here: https://gis.data.ca.gov/datasets/CALFIRE-Forestry::california-fire-perimeters-all/explore?layer=2
Try those and let us know how you did.
AprilWheeler
Correction: the wildfire layer isn't a polygon layer, it's a raster I believe.
RonaldHaug
MVP
Hi AprilWheeler,
Intersect is good.
and
AprilWheeler
Thank you RonaldHaug. I just got around to doing this. I'm not sure why I was struggling to Select the Living Atlas wildfire layer, but I was finally able to do it, then intersected the two layers, and I was able to produce a layer that showed the intersection between the two layers.
