"Retain tracks for:" keeps resetting to 30 days
270
7
2 weeks ago
JasonCyphers
Location tracking has been enabled on my enterprise portal, and I've set "retain tracks for:" to "always"; however, whenever I refresh the organization extensions settings page (or come back to it at a later date), "retain tracks for:" is reset to 30 days.
Any idea why this is happening and/or how to get the setting to stay "always"
AaronPulver
Hey thanks for reporting this. It seems to be a regression and actually still exists in the latest versions of Enterprise. I'll create an issue internally for this to be addressed for 10.9.1.
Luckily this is a UI only issue, when you change the setting from 30 to "Always" it is updating the back-end feature service correctly. When you reload the page, the UI is only checking for a property called "dataRetentionStrategy" which is the number of days to store tracks for. There is a second property called "dataRetention" which is a boolean which enables/disables the retention period altogether. When you change it to "Always" the "dataRetention" property is set to "false" which means the tracks are stored indefinitely. The UI is not checking that property and appears to only be checking the "dataRetentionStrategy" property.
If you navigate to the the admin endpoint for the feature service tracks layer (layer id 0) you can confirm this outside of the UI:
This with the 30 day retention period:
This is with the setting as "Always":
AaronPulver
Which version of Enterprise are you using where you see this behavior?
JasonCyphers
AaronPulver
JasonCyphers
I could not find the "dataRetention" property. Where is it?
AaronPulver
It's a URL like:
/server/rest/admin/services/Hosted/location_tracking/FeatureServer/0?f=json&token=XXXX
And then under the adminLayerInfo-->tableMetadata-->dataRetention (in the JSON)
JasonCyphers
got it, thanks!
JasonCyphers
Thanks!
