On July 6, 2023 we recorded a Tricks of the Trade session covering Survey123 report automation with Microsoft Power Automate. Thanks to all attendees! In this post you will find the recording, resources and Q&A.
Survey123 includes a report service. With it, you can create beautiful PDF reports including maps, photos, tables and more. Build your own reports for compliance, to document the work you do, to share information with stakeholders in a format they are familiar with or simply to create high quality printable documents.
If you are not familiar with Survey123 reports, check this recording first.
Using the Survey123 connector for Microsoft Power Automate, you can automate report generation. This webinar demonstrates how you can trigger reports when a survey is sent, and on a schedule.
Find the slides at the bottom of this post (They are attached in PDF format) or click here.
G'day All
In the 'new' Power Automate, when starting from scratch, for the Get file content step, it now requires the Id rather than the Path ... that or I messed up the step before. Anyways, for my flow to work I needed to use Id in the File parameter.
Hello @IsmaelChivite
I have a straightforward question that I hope you can answer. I have built an ArcGIS Enterprise custom connector in Power Automate using the Esri guide. I am still at 10.9.1 for the foreseeable future until we can migrate/convert all of our services, scripts, and mxds, so it wouldn't appear that the new Enterprise connector is supported. So my question is, does the custom connector ever expire and require manual reauthorization? I am only using it with trigger-type flows that use webhooks from the Survey123 website.
Thank you for any help you can provide on this!
dave o.
