Building Location-Aware Forms with the ArcGIS Survey123 Web Designer (Directions Magazine)
1027
04-19-2023 11:53 AM
IsmaelChivite
Esri Notable Contributor
On April 12, 2023, Directions Magazine hosted a webinar covering Building Location-Aware Forms with the ArcGIS Survey123 Web Designer .  In this post you will find the recording, resources and Q&A.
Highlights
Forms are a simple yet powerful way to collect information. They are regularly used to support many workflows. Forms are used to report incidents, document the condition of assets, assess damage to property...  Forms are used for permitting, to request and inventory equipment, as a safety checklist...
In many of these forms location is key. If you are reporting an incident, don't you want to make sure the incident location is accurately set?  If you request a building permit, would not you want to have the location of the building be accurate?
Survey123 is designed to help you build forms that collect accurate location information. Survey123 will also help you map your form data immediately.
This webinar explores the Survey123 web designer: A web based visual form builder.  The Survey123 web designer is an excellent starting point for you to start combining the power of forms and GIS.
Recording
Available here:  https://mediaspace.esri.com/media/t/1_gtvmym4w
Slides & Q&A
Available here.
