Zeros padding at the end of numbers
518
03-25-2019 07:10 AM
RawandDizayee
Dear ESRI team,
This is my my first question regarding OD for Arcgis i hope get rapid response i will appreciate it , my first question why i get two zeros from the end of the numbers although i gave integer type, second question i cant not see attachments in the detail. i attached two pictures clarify my questions. thank you very much in advance
MikailaBell
You have set a decimal field type, where you apparently desired an integer field.
You can create a new field with type integer and calculate the field to equal the original field. This will get rid of your "extra" zeros, after the decimal.
