Working on Survey123 Conditional Report Template with error ...undefined (reading 'value')
1771
6
08-27-2024 12:57 PM
Lisa_G
Hello, I have been working on a conditional report template for a Survey123 form. I have managed to eliminate all errors received so far, except for this last error.  Usually this error means something is up with quotation marks being the incorrect type. I went through my template and replaced all quote marks by copying and pasting from 'Quick Reference'. The form is a nested triple repeat so I figure this error may have something to do with the repeats. I can successfully upload the template, but when I attempt to run a test print, I get this error - unless the form I am printing only has one child, then it will print. When the report has multiple children, it fails. I really need some direction on how to capture the repeats in the report template. I have attached the template and the xls sheet.  Thank you for any assistance!
abureaux
MVP Frequent Contributor
This error could be a bunch of things. Did you make this template yourself specifically for this survey, or is this a random decade old template that you converted into a feature report? Just last week I was battling with an old client template that kept giving me the error you see for seemingly no reason. I gave up, remade it from scratch to look exactly like the original, and everything worked after that.
Unfortunately, you are using capitals in your names so I cannot recreate this on my end through Connect. No actual testing means I can only do a visual sweep, which isn't always sufficient, unfortunately.
appearance:multiline needs to be on a new line. E.g., turn this...
into this...
Not a syntax issue, but it looks like you will run into blank space issues with all that dynamic content. If you swap your IF() statements from this...
to something like this...
You wont have as many blank spaces.
Didn't see anything else that jumped out at me. Again, a visual sweep isn't as good as actually testing, so there's a decent change I missed something.
Lisa_G
Hi abureaux,
Thanks for your response. Regarding the report template, it's not an old template. It's one I created myself this week. When I run into errors on the template, I usually start all over again from scratch and it usually helps. But in this case, I figure I don't have experience with how to set up repeats in a report template. I'm researching for help on the repeats. Thank you for the example you gave on how not to have so many blank spaces. I used the dynamic content approach as it was the only way I could get a photo identified in a report. I will definitely clean up all my photo questions as you had suggested, that is super helpful! I guess I need an example on report template repeats. Many thanks again, Lisa
abureaux
If this is a template you made yourself, then you are likely fine on that front. I only had to mention it because old templates can sometimes cause issues. But regardless, this word file looked well put together, so I didn't suspect that was the issue in this case.
Again, I wish I could test this myself. Best of luck with troubleshooting!
If you didn't already know this, I wanted to add on one thing about IF() statements in Feature Reports (this is mainly what I ended up looking for):
  1. An IF() statement must start and end either inside or outside a table. E.g., You cannot start the IF() statement inside a table and end it outside the table. This will result in an error.
  2. IF() statements within tables must start and end as the first and list things within the table or the table row
Lisa_G
Hi abureaux,
Thanks again for the IF statement examples. I learned by trial and error myself but it is great to see another approach. Self learning can have gaps! I do have a question for you on how using capital names affects the ability to recreate on Connect? I have read quite a bit on Survey123 but I haven't come across lower case names yet. Can you explain a little further? I would appreciate that!  Many thanks, Merci, Lisa
abureaux
It's kind of a silly limitation.
But, when creating a Feature Layer via Connect in an Enterprise environment, upper case letters are not permitted:
However, if the layer is published from, say, ArcPro, and the names have capitals, you can create a survey based off that layer without issue.
I am also fairly sure that this limitation doesn't exist for AGO at all. So, it's really just this one niche use-case where capitals are an issue. I really hope they resolve that someday.
abureaux
Meant to add, but playing 20-quesions with your Feature Report is never a bad thing. Cut out half the content, see if the error goes away. Get the Feature Report to a point that it parses successfully. Then, start adding content back in until it breaks.
Generally, this works very well. I can get through a Feature Report that's a few hundred pages long relatively quickly doing this.
However, I will add that this method doesn't work well if the word file you are using is just plain buggered. I've found a few times now that converting old word templates that someone made many years ago into a Feature Report doesn't always yield best results. In those few cases, I recreate the word file from scratch to look like the original. As a last resort it's worked every time.
