Working offline with survey123 with offline base map
6065
05-30-2017 06:23 AM
NDA-GISGhana
Please how do I work offline with survey123 with an offline base map just like collector for arcgis.
I am currently working in a location where internet accessibility is a challenge but the survey requires location as a key indicator. Thank you.
JamesTedrick
Esri Esteemed Contributor
Hi there,
Information on preparing a basemap for offline use is available at Prepare basemaps for offline use—Survey123 for ArcGIS | ArcGIS .  Tile packages can be created either using Desktop tools or using ArcGIS services (for the latter, GitHub - Esri/TilePackageKreator: Tile Package Kreator is a useful tool to automate the process).
JamesTedrick
Hi there,
NDA-GISGhana
Thank you James
AnussaraHirunpongchai2
Hi James (James Tedrick‌),
First of all, I'm trying to use my own basemap in Survey123 by following Prepare basemaps for offline use—Survey123 for ArcGIS | ArcGISsteps. Also, i used their Tiled Package link from the document and i published my own Tiled Package, which i downloaded from the document link, to my ArcGIS Enterprise for testing. However, it doesn't appear on my app no matter how i tried to republish it. Please see my picture form below. So, i I would like to ask you that how can i show my own Tiled Package on this Survey123 by using ArcGIS Enterprise 10.6.1.
Best,
Anussara H.
