I created a survey in ArcGIS online and shared to the Public, but people stille need to login to see the results. Does anyone has a idea?
Bests,
Fiona
I see. Yes, this is also expected: The Survey123 website, when used anonymously, only shares data trends (analyze tab), not the specific record info.
Here is what I suggest:
This is by design. Check this blog post for details: https://community.esri.com/t5/arcgis-survey123-blog/securing-data-in-public-surveys-survey123-web/ba...
If you want to share your survey data, you will need to create a view for sharing or use the Collaborate tab.
Thank you for the answers, I have go through your blog and checked my settings, under the Collaborate/share survey:
Who can submit to this survey? Everyone(Public).
What can submitters do? Only add new records.
under Collaborate/share results:
Who can view results of this survey? Everyone(Public)
And in the ArcGIS online content, all items are public except the feature layer(it's private), but when I share the link from "Share survey results", it comes only the data(records,tables), not the map with points. And if I share the link from "Data/share/link to this page", it will need login to overview the results.
Bests,
Fiona
I see, thanks you for your answers 🙂
