Why are Generated File Names Different in Survey than File System?
1194
7
04-27-2019 11:20 PM
AaronColbran1
New Contributor III
When file names (image,audio etc) are generated from images they display as the FieldName- + UUID + .ext
When the files are written to the "My Survey Attachments" folder they are written as FieldName-YYYYMMDD-Rand(6).ext
Name During Live Survey: BoreLeakagePhoto-c3fff6884a6949149d77fdcdbf837a5c.jpg
Name After Written to File: BoreLeakagePhoto-20190416-050430.jpg
The fact that a UUID is displayed at File Capture Time, but is replaced by a Date and a random number at storage time (My Survey Attachments folder) makes it impossible to create a workaround for this file management issue.
Why is the UUID displayed if it is never written?
Is there a way to replace the 6 Digit Random Number?
A basic workaround normally would be to add a custom prefix from an active survey field such as an IDENTIFIER CODE.
Currently the only way to identify one photo from another is the 6 digit random number before the file type extension. As a result the Survey Attachments folder fills with any number of non-differing names other than the random 6 digit suffix known as "?"     FieldName + YYYYMMDD + ? + .ext
or my active semi workaround which is stored in the table until the image needs to be renamed.
${WORK_NO} +'_BoreLeakagePhoto' + '_' + format-date(${SurveyStartTime},'%Y%m%d') + '_' + format-date(${SurveyStartTime},'%h%M%S') + '.jpg'
Optimally names would be auto-generated from form data and custom calculations saving hours and days of downtime renaming and auditing files.
Is this fundamental issue of basic file management on the roadmap?
by Anonymous User
Not applicable
Hi Aaron,
Can you please share a copy of your xlsx file and the exact question you are seeing this issue on, and also what device you are using, does it happen on all OS (Windows/Android/iOS etc)? Please send through the make/model/OS version so we can take a closer look.
Regards,
Phil.
AaronColbran1
New Contributor III
Hello Phil
Thankyou for your time on this question. The Tablet Samsung Galaxy Tab A 10.5 T595 (32GB, 4G LTE).  I cannot supply the xlsx at this time. The issue is not related to the survey itself, it is the way the S123 image control names its written files.
The main issue for resolution is the inability to control file naming due to the application displaying a filename that is not the actual name of the file. The displayed filename at time of capture in S123 is "FieldName-UUID.jpg", but the actual name of the file stored on the tablet is "Fieldname-Date-RandomNumber.jpg".
Currently the only way to identify which photo belongs to which survey is by the 6 digit random number, which is a bit random, unless data is successfully exported to an FGDB where it is organised by UUID and can be processed and aligned.
This issue compounds as for any one survey on any one day hundreds of photos may be taken with similar but unrelated names.  The simple task of aligning images to surveys is made more complex as the filename you thought was the name is no longer the filename.
My planned approach/workaround to the issue was to Generate the "filename" required with Time and Date Stamp to Match the SurveyStartTime to identify it against a survey. This was done in an extra text field as the image field in S123 does not store the name of the generated file.  This is not possible however as I cannot control the naming process and the S123 application names the final file different to that which is displayed in the survey.
Aaron
by Anonymous User
Not applicable
Hi Aaron,
What version of Survey123 are you using? I just tested with 3.3 and 3.4 beta and am unable to see the same behaviour you describe above. If I use the camera icon to take a new photo, the image name displayed in the form is the same as the image name of the file created in the My Survey Attachments folder. I tested this on both Windows and Android. I also tested selecting a file via browse on an image questions, and using the annotate or draw appearance, as well as audio recording, all of the file names in form match that in the folder.
Note that images taken with camera do use a different name to those by browse image and audio? One uses random ID versus the UID. This was the only difference I saw.
We have an open enhancement request in our backlog to enable the user to set the image name via calculation so that variables can be passed and used to the set the desired image name. I have updated with your comments.
Phil.
AaronColbran1
New Contributor III
Hello Phil
The S123 version on the field tablets (T595)(tablet photo test) and windows 10 (file browse test) is 3.3.64. These do UUID on the device but they do write the proper data based name to the file system.  PhotoDeparture-20190424-011500.jpg
On the office Samsung 2017 Tab A testing tablet is v 3.1.159. This earlier version works as per S123 normal (Field-Date-Rand6.jpg) in form display and file export.
So my planned workaround is not working the way I planned. Images for us are a key piece of evidence linked to a fixed asset. There are 500 assets and 13 photos per asset site that are now autogenerating a guid label in the field.
If there is no way to resolve it at this time I will update the survey output naming convention to part match the outputs.
Hopefully the control calculated name update can be shuffled from backlog to frontlog as there are a number of users that have also been seeking this functionality based on form data or selections.
Input vs Output
by Anonymous User
Not applicable
Hi Aaron,
In your two screenshots I do not see the same photo, the one taken in the survey form is a field named BoreField7DayWaiver, but I do not see the exact photo for that in the gallery you are showing, either way it should have the same start prefix of the field name, but also the thumbnail should look the same. If you can show the same thumbnail I think you will find they are named the same?
Phil.
AaronColbran1
New Contributor III
Gday Phil Yes that is the case, as it is just a sample photo to show the S123 3.3.64 UID name vs the ID name that it is .  The first example was from the tablet version 3.3.64 before it went bush. The other is desktop version 3.3.64. writing to the file system. The images below are captioned.  Hopefully they should clear up what is happening.  Note there is NO BoreField7DayWaiver image captured as data yet, hence the 'BoreSite' photos.
The mixed result and confusion here is due to the fact the older version tablet v 3.1.159 was actually being used in the field when the normal Survey123 names were being written 'S123 3.1.159 Tablet File System Synced' image.    Now it makes sense!
The 'S123 3364 AGOL' image shows the current version I just loaded from the windows desktop using the 3364 survey which writes the full guid.
S123 3364 Tablet Display
S123 3364 Tablet Display (Ignore the name in text. it was the name I was trying to generate as Plan B)
S123 3364 Tablet FS
S123 3364 AGOL
S123 3364 AGOL
S123 3364 Windows 10x64 Display
by Anonymous User
Not applicable
Hi Aaron,
It appears with version 3.3 you are seeing the correct behaviour in what is displayed in the app on the form, saved to filename in attachment folder and uploaded to AGO, all of them should use guid and be the same, which is what i see above and in my tests. The older version of the app and process used a smaller random number instead guid, and this may be part of the confusion.
Phil.
