Why a field "select multiple" return code (and no value) ?
1606
03-28-2019 07:30 AM
ArnaudDemontis
Dear Survey123 community,
I have a problem in the result of my survey : when I look a survey in ArcGis Online or an excel files (after an export), every "select multiple" field return the code and no the value checked.
Anyone has the same problem?
Many thanks for your help,
Arnaud
IsmaelChivite
Esri Notable Contributor
Hi. The output of a select_mutiple is by default a comma separated list of all selected choices. This is by the XLSForm specification.  If you would like to split selections across multiple columns, you can do that by adding hidden fields and calculations.
Some detailed discussions around how to do this can be found at:
Hope this helps!
JamesTedrick
Esri Esteemed Contributor
To add to Ismael's reply, you can display multiple choice labels in pop-ups using Arcade:
https://community.esri.com/groups/survey123/blog/2018/10/10/labels-for-multiple-choice-questions-usi...
